Sensitivity adjustment will not change from 50 percent
  • 3212 Views
  • 3 Likes
Gman001
I just had a 50 Brute Garbage bin stolen right in front of my Arlo Pro.  Sensitivity adjustment is so disappointing.  It indicates 50 percent, then I change it to 100 and when I recheck it indicates 50 percent again. So I try again and again and no difference.  Was it ever at a 100?  Does it reset each time I invoke it???  So UI and sensitivity are so amateur!!  I expect better.  Am I missing something? Thx.
Yes you are...prob the SAVE. ( don't feel bad, its on the prev page )
Do the adjustment to the sense level...most of mine run 88-93%.... the hit the EDIT RULE above
this will take you back on page and SAVE is at the bottom
it should stay set then
UpperLeftEdge
I'm also trying to adjust the sensitivity and I can change 50% to different value but no option to save (not on previous/back a page. What gives???
App or browser?  The app has a Back selection while the browser requires that you use the Edit Rule link instead. In both cases, Save is available after you go back that one page.
