Sensitivity adjustment will not change from 50 percent
I just had a 50 Brute Garbage bin stolen right in front of my Arlo Pro. Sensitivity adjustment is so disappointing. It indicates 50 percent, then I change it to 100 and when I recheck it indicates 50 percent again. So I try again and again and no difference. Was it ever at a 100? Does it reset each time I invoke it??? So UI and sensitivity are so amateur!! I expect better. Am I missing something? Thx.
Yes you are...prob the SAVE. ( don't feel bad, its on the prev page )
Do the adjustment to the sense level...most of mine run 88-93%.... the hit the EDIT RULE above
this will take you back on page and SAVE is at the bottom
it should stay set then
App or browser? The app has a Back selection while the browser requires that you use the Edit Rule link instead. In both cases, Save is available after you go back that one page.
