Scheduling showing incorrect date and time set
Hi,
I am trying to use the scheduling to set up my new Arlo Pro system, I am having two issues.
The first is that when setting a mode for Monday-Friday 00:00-5:30AM, although i am selecting only the days monday-friday, when I press done it then also incudes Saturday. When trying to edit the time slot to remove it, it will not allow me to remove Saturday.
The second issue is that when setting a time zone, if i put the Stop Time as 6:30AM it shows on the caledar as 5:30AM. This only happens with the Stop Time, the start time works as you would expect.
Make sure your time zone is set properly in Settings, My Devices, your base, Time Zone.
WHen setting the schedule, try using a browser since that seems to work better for me.
