Scheduling not working
  • 8 Replies
  • 7756 Views
  • 2 Likes
  • 6 In Conversation
Fifiwesfan
Hello.  I set a schedule for my Arlo Pro but its not working.  Under devices its says all the cameras are off.  Under Mode, it says my base station is armed.  I searched the community and found an answer to turn off/on the base station.  I did that but it didn't fix the problem.  Any advice/suggestions would be appreciated.  Thank you!
8 REPLIES 8
Ysabel
Luminary
Luminary
If your cameras are showing offline on devices, check if your cameras turned ON. To check it go to > Settings > My devices > Select camera > check turn ON and OFF. If camera it doesn't show you the turn ON/OFF camera, that means your cameras are really offline.
To fix it, follow the steps on this knowledge base: https://kb.arlo.com/1133448/My-Arlo-Wire-Free-or-Arlo-Pro-Wire-Free-camera-is-offline-how-can-I-trou...
TheGardners
I have the same issue. All cameras are online, but schedule does not work. If I have it set to be armed from 12am to 6:55am and enable that mode at 5am, the system should be armed immediately. Not only does it NOT arm right away, but the next mode (Set to begin at 6:55am, partially armed [some siren activation, but not all]) also does NOT activate. Why will none of the modes activate while in Schedule mode?
Try using a browserto set your modes/rules/schedule up. That seems to be working better than the apps.
TheGardners
I did set up all of the modes and the schedule using a browser. I only tried setting the mode to Schedule via the app. I will try setting it to Schedule mode via the browser and see if it actually applies the defined schedules.
Fifiwesfan
Thank you for all the suggestions.  I tried all of them and the scheduling is now working.  The scheduled hours got pushed back and hour somehow but its working.  Much appreciated!
Arlogal
I did that and it didn’t fix the issue. I have been having this problem for weeks and siooort can’t help.
Arlogal
I tried doing it through the browser and it didn’t work. Support is useless and now it’s dropping my Monday schedule which ironically was set as a weekly schedule but all the other days/times are fine.
New Base station firmware has been released that should help resolve the issue being discussed here. Check your base station firmware to be sure you are up to date with the latest available version.
Take a look here for more information on this firmware: Firmware Release Scheduled 6/21 to Address IR Rapid Battery Drain and Modes and Schedules Issues
