Scheduling logic isn't working. Cannot make schedule between 9:30 PM to 4 AM
  • 1 Reply
  • 879 Views
thisguy
I'm either not understanding the logic behind what should be a simple task or there's something wrong with my system or the talent behind the logic.
I'm only able to successfully set a schedule from AM to a PM time. If I want the cameras on between 7:30 AM and 3:30 PM there isn't an issue. Where I'm unable to make this a workable solution for me is setting the time from PM to AM. For example, I'm unable to make a scheule for the cameras to be on between 9:30 PM and 4:00 AM. What am I doing wrong or is this $500 camera solution a bit of a usless brick?
brh
@thisguy
Since 12:00 am starts a new day, most systems require you to have two schedules if the day changes. So, set up one schedule from 9:30 pm to 11:59 pm and then another schedule from 12:00 am to 4:00 am.
Brian
