Schedule setup help
  • 1 Reply
  • 1141 Views
JLinhardt
I need help. I cannot seem to get the scheduling task right. I have three cameras. I want two front door and garage to run 24/7. The back door i want to run m-f 12-5:45 then 7:30-4:00. Then 8:30-12. Then sat and sun 12-7:30 then 8:30-12. I have amode for the two cameras ans one for the back door. I just cannot seem to get it to work.
Ok , as long as you split the cameras into groups already the problem isnt to hard
Remember the ANY cam NOT in the active mode will be OFF
Since the front and garage run 24/7... USE the ARMED mode ( all on ) when the times above include the Back door.
In the NON back door times use the mode for JUST the Front and Garage
