Schedule not working with Gefencing
I am able to configure Custom Modes, Schedules, and Geofencing, and everything works as expected.
However, when I set up Gefencing with to use Schedule while I am at Home, the cameras are not recording/notifying as expected (when I am at home). The Mode tab on my iPhone app correctly identifies the Custom Mode that is in effect, but that cameras are not triggering / recording / notifying per Custom Mode.
If I switch to Schedule mode while I am at home, the cameras work as expected. It appears that the specific combination of Gefencing > Schedule causes the cameras to not do anything.
Any ideas?
In Geofencing, Are you using the Scheduled Mode as the "home mode "?
Yes, I am using "Schedule" as the "Home Mode" in Geofencing.
Slaven,
Check your Schedule to make sure the appropriate modes are set up correctly for the desired times. It sounds like you may not have the "Armed" mode set during the desired time frames.
