Replace or Repair?
  • 2 Replies
  • 3901 Views
Stangle
I've got a camera that keep rusting batteries. Apparently, whatever is under the SYNC button has failed as it's depressed and wil not pop back up. I think water is getting in there and possibly from underneath.
What is the repair cost for a VMC3030?
Thanks for your time.
Don't think there is any repair for these cameras....
If less than a year you may get a warranty claim thru support.
If more than a year, I would put a quality type electical tape over the button to seal it and still allow usage.
Stangle
Thanks for the idea, but it went offline and would need to sync with the base station. Look like its time for an upgrade. Thanks!
