Are you using the library in the app or a browser or clicking on links in an email notification?
Unistall and reinstall the app.
If possible ,check on a web browser / computer to see if the files are in the Library.
In this image you have the filter set in the library. That's the funnel icon filled in green. Click on it and reset and save it to get an empty icon. You should then see all videos for the day. The filter gets set when you click on the numbered circle for a camera in the Devices tab.
As jguerdat said, this funnel is solid green meaning you have a library filter on for a specific camera. Click the funnel and reset the filter so no boxes are checked. The library will then show all recordings
When you're in your Devices tab, if you click the number of recordings in the circle above each camera, it'll open the library with the filter on for that particular camera. If you've freshly opened the app, clicking the library tab should show everything
I’ve tried rebooting, I’ve tried resetting, I’ve deleted the app and reinstalled it. Nothing, still continues to show the number of recording but then when I click on it, the disappear.
Did you try through your web browser on a PC?
Have you power cycled your base at any stage?
I guess this is where you need to open a ticket with support if you haven't already. Sorry we couldn't be more help
Spaceninja wrote:
Forgot to mention, I reset each camera individually, and when I check the each camera again the funnel icon is green again? Like it’s not resetting. However the library funnel is clear.
This may be the root of the problem. Instead of clicking on the numbered circle for a camera in the Devices tab, which will reset the number back to 0, simply use the library tab. Ensure the filter is cleared. All videos should then be seen.
If you click on a camera's numbered circle, it turns the filter on by default to only show the single camera's videos.
