Is there a way for the ARLO PRO to continuously record?
Or at least more than 300 seconds, Like 30 minutes (1800 + seconds) or at least restart the timer when motion continues?
The only way to get more than the time allowed in the MODE is to manually start a record session... IIRR, it will record for about 30 mins before shutting down to preserve battery.
The way it is now, it will record for say 2 mins...then the camera goes thru a reset motion cycle of about 10 secs...if it still sees motion after resetting, the record time will repeat.
