Recording Time CANNOT Upto 300sec,.
The Record TIme already change to "Record until activity stops (up to 300 sec)", it SAVE successful.
The motion records, always cannot be done for full 300sec even the motion still going on, it will split to 16~31sec, it seperate with different record.
(When I was washing the car, the camera can detect motion, but keep seperate the records)
I tried RESET the Control Based, Remove, Resync the Cameras, all same. (I have try for 2units of VMB4000 Control Based, 9 Cameras)
Anymore help ??
Model:
VMB4000, Arlo Pro
This has been seen before...i recommend putting it back on a set time of your choosing and contact Netgear Support re this issue
please search topics before sarting a new one... there are 2 threads already active on this topic.
the best way is to. slect the second option under the recording tab and select to record for a spefic time and set to 2 minutes, not the top setting of when activity stops
