I'm having trouble with the Angle of the Camera...
As you can view...The car that's coming into the frame from the RIGHT...seems to be starting in the middle...it didn't capture the car as it comes in...
How is this possible and How can I adjust it?
(Click the link to view)
https://arlo.netgear.com/hmsweb/users/library/share/link/6F2A192F5733B5F6_201806
There are a couple of things....
the truck appears in the middle due to its speed and the delay of the start up of record. There is not much you can do with the normal 1-2 sec delay except
You might be able to increase the sense level
Move the camera closer or use two front cams one looking each way ( from ends of home )
Try turning the camera as some are more sensitive on the left or right side of the PIR or lower the angle
Get one Pro2 camera and run on ac as then you will have a 3 second look back
Do you really need to have the whole street view? People motion detection is only up to about 25 feet so why record cars on the street?
