Push Notifications not Consistent on iPhone
I noticed last night and again this morning that my Arlo Pro is not consistently sending me push notifications when on Alert mode. I have four cameras and can walk right past one of them and do not receive a push notification of motion detection. Then I can try the same thing with another camera and will get the push notification. And then I can do it all again to test it out and won't get a single push notification for any of the cameras. I just downloaded the iPhone 10.3.2 update this week and am wondering if there is a problem with it and the Arlo app. I'm just concerned that these cameras are not working properly now. I did a motion detection test this morning, and they all flashed as it says they should. All of my push notification settings are on for the app. I'm at a loss. Can anyone help???
sheltieamore,
Consider rebooting your mobile device along with the base station (using the on-off) button. Do you still see the same behavior?
i have set up all camera's and working fine. how do you stop it from emailing everytime there is a noise or motion. I just want my camera's on motion not sound. please help
