Vorschläge aktivieren
Mit der automatischen Vorschlagsfunktion können Sie Ihre Suchergebnisse eingrenzen, da während der Eingabe mögliche Treffer angezeigt werden.
Suchergebnisse werden angezeigt für
Themen-Optionen
- RSS-Feed abonnieren
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Anstößigen Inhalt melden
Hello, I own two Arlo Pro 4 cameras, which have so far only been powered by battery. Since the battery life is weak, I wanted to connect them to a power source using a longer charging cable. After searching for a long time and not being able to find an original charging cable, I bought two chargers, each with a 6-meter charging cable.
Initially, both cameras worked when I tested them before mounting them on the wall. However, after drilling holes in the wall and installing the wall socket, the cameras stopped working. Previously, I had tried charging them with the original charger and cable, and that worked (79% and 98% battery charge, respectively).
Could you please tell me where I can buy an original 6-meter charging cable and a compatible charger in Germany? Since I already own one charger, I need two 6-meter charging cables and a charger that is compatible with the Arlo Pro 4.
Another question: My front camera is pointed at the road, and part of the road is visible. How can I pixelate this area? Would a 360° mount help? I already have a magnetic mount. Can you please help me?
Gelöst! Gehe zu Lösung.
Beschriftungen:
- Beschriftungen:
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I am unsure where you can find a charger and cable. You will need to research that online and see if you are able to find one/
We do have activity zones
1 ANTWORT 1
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Beschriftungen
Bevor Sie kaufen
Bewegungssensor
77 -
Community Ankündigungen
Dienste und Sicherung
45 -
Versionshinweise
23 -
- « Vorherige
- Nächste »
