Pro too sensitive to noise. Tried lowering the audio and microphone off.
  • 1 Reply
  • 1344 Views
hileywoo
Our 2 Arlo Pro when we first purchased them 3 years ago worked well outside.
The last year or so with various updates have caused the devices to become too sensitive to noise, a bird noise. We have tried everything turning audio to zero and microphone off but have not been able to solve our problem can anyone advise if there is a way to decrease Arlo’s  noise sensor ?
JessicaP
Hi hileywoo,
Try creating a new mode/rule to see if that might help with the audio detection.
If you don't want audio detection from your cameras (since you mentioned you turned your microphone off), you can always disable the audio detection as well, which you can read here to learn how: How do I enable or disable motion or sound detection?
