I recently changed my WiFi to Starlink and now my Arlo Pro cameras will not work says offline. I don’t know how to change the WiFi settings
The wifi is generated by the Arlo hub, which is connected via ethernet.
Is the hub/base station also off-line? How is it connected to your Starlink system? Does your Starlink router have ethernet LAN ports (some do), or are you using a Starlink adapter
