1 out 5 camera with broken motion detection. it got stucked in recording (orange light on) and stopped working. i have done allthe trouble shooting. please send replacement. i only had it for 1year. not good for your company
Message 1 of 5
1,203
Not knowing what you have done other than "all troubleshooting"...
Pull battery, replace. Then use remove device for camera to delete and reboot base via the power button ( off-on ) then bring camera back as new ; add device
Message 2 of 5
1,195
hello mr Guru! i've done it about 324 times and still no luck. please send me a replacement. Arlo should not have issues with sensor after couple of months
Message 3 of 5
1,188
This is a user forum, not official support. If you think you have a hardware problem, use the Contact Support link at the bottom here. However, if the motion icon is amber all the time, try clearing the cache for the app and/or browser you're using.
Message 4 of 5
1,172
not worth the money! don't buy arlo!
Message 5 of 5
1,167
