Pro battery went dead while we were gone. Charged and replaced but blue light comes on and stops.
My battery went dead while we were gone. Came home fully charged battery and replaced. The blue light will come on for 2 seconds and then stops. I push the sync button and I get nothing. It is 1 out of 4 cameras and the others work fine. Probably 5 years old now.
Power button reset the base
pull battery and replace to reset camera
Press base sync button ( dont hold ) and then camera sync button.
( fast blue on camera means it synced )
If NG, pull battery and hook up the ac power only to see if battery is causing an issue...repeat sync
