My battery went dead while we were gone. Came home fully charged battery and replaced. The blue light will come on for 2 seconds and then stops. I push the sync button and I get nothing. It is 1 out of 4 cameras and the others work fine. Probably 5 years old now.
Power button reset the base
pull battery and replace to reset camera
Press base sync button ( dont hold ) and then camera sync button.
( fast blue on camera means it synced )
If NG, pull battery and hook up the ac power only to see if battery is causing an issue...repeat sync
