Possibility to add Arlo Pro Cam without pressing sync?
  • 0 Antworten
  • 1148 Aufrufe
  • 1 in Unterhaltung
TrionixSl
Hi all,
I have an issue with one of my Arlo Pro Cams. Yesterday the Cam hangs (full white screen) and start/stop was not bringing it back to the normal mode. I removed the Cam and tries to add it again to the base station. Unfortunately I was not thinking enough, because the Cam is mounted on the (more than 6m) so I don't reach it to press the sync button. Is there any other option to add the Cam to the station (VMB4000)?
Thanks!
0 ANTWORTEN 0
