Has anyone experienced pixelating video in the first 2-3 seconds of the recorded video. It happens every time for me. It has great reception full Wifi bars... and does not happen with my original Arlo camera.. just with the new Pro.
I too am having some pixelization as well on all 4 of my Pro cameras. My upload speed is 2.5mb normally. My local USB recordings arent showing the pixelization so I believe that means it is more likely that it is Netgear's servers or intermittenent ISP upload congestion.
@sharkcom my local USB recordings show the artifacting and ghosting. I'm 100% confident that this is a Arlo Pro isolated issue, I never had this issue exhibit itself in the first gen cameras.
I think we should start posting our clips to Youtube as "Arlo Pro video issues". Maybe Netgear will step up their efforts to research and resolve the issue.
Wanted to give a quick update. I borrowed 2 Arlo Pro cameras from my brother. All I did was replace my 2 bad cameras with the 2 borrowed ones. Been up for 2 days and they seem to be working better. I still see occasional pixilation, but a lot better than what it was.
If the video stays as is, I think I can live with it. Will keep the forum updated on how it is working.
robsss: Are the rev's the same? All H7's? Same firmware? If their like for like...and one is worse than the others...signs point to hardware issue to me.
All of the Cameras were H7 and purchased about the same time. One set from the local Best Buy, the other set mail order from Best Buy.
I did not note the firmware version of the older cameras, but all of them had a recent update. So I will assume they are on the new firmware version.
I see occasional ghosting/pixelation from my cameras as well. I'm also an I.T. Engineer and I've worked extensively on testing, position, distance to base, etc. I've moved the base and tested and it has had no effect either way.
Here are a couple examples of what I see:
https://arlo.netgear.com/hmsweb/users/library/share/link/FC70574D79EC0568_201701
https://arlo.netgear.com/hmsweb/users/library/share/link/E1AA3316E4EBBA99_201701
This is from two different cameras. I have 5 total.
Kmiller8821: those possums have good balance, LOL. Your video's sum up the issue perfectly.
Yes, they sure do. lol. It's the first time I've picked up any wildlife on my arlo cameras, that was definitely interesting to see. I'll be checking with my neighbor to make sure his trash cans are sealed out there so we're not feeding those things, we need them to go away.
manofice wrote:Kmiller8821: those possums have good balance, LOL. Your video's sum up the issue perfectly.
Kmiller8821- that is exactly the same issue I am experiencing on a couple of my cameras as well. I can live with it for now but wonder if I should try to swap them out. I will switch around the cameras to different locations and see if the issue follows the camera.
I have experienced the same issue on one of my cameras. The lack of customer service from Netgear and their slow action to address issues is really concerning.
After weeks of things working perfectly, now I'm getting pixelated video and stuttering. People walking across the field of view, etc - stopping as the video plays and then showing up a few feet further when the video "comes back". Happening almost every time now when it hasn't happened at all previously. Nothing else changed on my network. Excellent WiFi reception. All bars.
I'm having the same issue. It is only happening on one out of the three cameras I have. The camera shows full wifi signal strength and battery is fully charged. When I view live video, the issue usually doesn't happen but it happens on about 1/3 of the motion-detection video captures. Video will have artifacting or be frozen for a few seconds or show a green bar across the picture for part of the video. Audio plays fine the entire time.
Pretty sure all our camera's and base is up to date.
