  • 2 Replies
  • 1643 Views
superfurry
In the new Arlo app it appears that its now not possible to mute notifications at the individual camera level in custom modes, and that you can only mute notifications across the whole app for temporary periods (30mins, 1hr, 3hrs, 24hrs)
In the old app you could set up notification settings per camera, and permanently mute if desired.
Do I have this right, and are there any plans to reintroduce this lost functionality?
@superfurry wrote:
Do I have this right?
You can still go into the camera rules in each mode and turn off notifications there for that camera - just as you could with the old "Library" interface.
Ability to temporarily mute all notifications is also the same as it was in Library.
Custom modes are being put back, though still a work in progress.
superfurry
thx for pointing that out!
