Outdoor Security Mount in White (VMA1000) on the vertical wall possible
  • 1 Reply
  • 2288 Views
waynekhin
May I know if it is OK to install the "Outdoor Security Mount in White (VMA1000)" on the vertical wall?  I only see the sample photo in which the Security Mount was used to install on the horizontal surface.
Thank you.
Wayne
Streak2
Master Master
I have mine installed on a vertical wall no problem.
Streak2
Master Master
