Original USB Charger and cable not compatible
  • 4947 Views
Andy1628
Issues with charging my camera battery with the original USB Charger and cable. Message indicates charger not compatible. Anyone have a fix ? Arlo support please help !
AncientGeek
Hero
Hero
I recieve that same message from time to time on my solar panels and wall chargers even though they are all Arlo original products.  If this is an intermittent problem, but not a permanent problem, then you may see it from time to time until Arlo figures out what caused this glitch.  If your problem is permanent, then I'd try different camera/charger combinations if possible to see if one of them is truly faulty.
did you swap a battery with another to see if its the camera/adapter or the battery?
AncientGeek
Hero
Hero
Andy1628
Changing the charger solved the problem. Thank you
