Any idea what this is? I've been thru this app 50 times...Zero clue.
FYI, It will take a day or two for the image to be viewable by others here on the forum, until someone from arlo approves it.
@Riesel81 wrote:
Re: Orange Dot
It's calling your attention to a setting that might need to be updated. For instance, if it detected that you moved the camera, you will see this indicator to remind you to adjust the activity zones.
If you go deeper into settings, you should see the orange dot next to the setting you should check.
