Opinion:2 Hubs and 4 pro cameras or 1 hub and 6 pro cameras
Thanks in advance
"It depends." (TM)
Being able to spread the cameras out can be a good idea but more cameras might be more worthwhile. All depends on what you're after and need.
Time to load the image
Battery life
Viewing response time
My view is if two hubs does that better I can always but individual cameras in the future as needed.
"It depends." (TM)
Either way can make sense. More range or more cameras.
Just a note that no one else mentioned.....
If you run two bases, each one and the synced cameras to that base unit will be separate from the other.
Tho you can view all the cams in the same app/prgm, each base unit will have to be armed/scheduled/etc by it self.
So if you have Base 1 and cams 1,2,3 AND base 2 with cams 4,5.... you will have to armed each base or schedule each base and associated cameras separately.
Once again, it depends on what your needs are.... I like two bases as I use one for inside and one for outside the home... for me it's easy to turn off one set without making a lot of custom modes...YMMV
Also each group, inside and outside, can run on their own schedules
