One of my cameras won't sync. Connected to charger and will show blue LED for 2 seconds.
Hi, one of my cameras won’t work, they are all synced except that one, when connected to charger it will have a blue light for about two seconds and then nothings else. If I click sync button nothing will happen.
Is the camera showing in Settings, My Devices? If so, try removing and resyncing it. If not, it sounds like a hardware problem so use the Contact Support link at the bottom here.
