Beside the money scam giving the log in and password which is good you changed it. This is part of the reason 2FA is a standard now for most security cams. There have been multiple post with the same situation as yours here.
Sounds like you called a "fake" Arlo support... FW updates are free
they are ONLY here : https://www.arlo.com/en-us/support/contact.aspx
As to the camera, I'd swap two around and verify it's the camera and not location for some reason... if the problem follows the camera then I'd reconfirm the settings for the camera ( simple camera reset is pull battery and then reinstall )
If need be still issues you can always remove the camera and bring it back as if new ( use remove device )
