One Camera is not connecting
  • 2 Replies
  • 4467 Views
DonRon
I realy like Arlo and just bought my third set, this time the new Arlo pro with 4 camera's. 3 of them are working fine, but the last one shows an slow amber light a few times and doesn'r connect. I tried this one to bring close to another base station, but also the same light and not working.
I took the batery out a few times. No results. What can be the problem with this camera?? Any one has an idea to try?
Remove the battery and just use the AC adapter and usb cable...see if it syncs then ( quick push on base sync button , dont hold )
DonRon
Yes, that did it! Thanks a lot!
