Title says it all. 2 of my cameras said they had 15% battery life. Plugged one in and it recharged fine. The second one will not recharge. Tried different outlets, taking battery out, inspected prongs. Nothing seems out of sorts. Please help me trouble shoot.
Check the FAQs, there is a page from Arlo about batteries not charging....
basicly, put the battery in and use supplied adapter, if not charging then pull battery, wait 10 min and then insert again ...repeat 6 x
if the battery get to low, it will not charge and doing above gets it to a level where it will
Thank you. I did use common sense first. Unfortunately, the FAQ section did not work. I appreciate your input..
heres the article; https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Thank you. Unfortunately, as indicated in last reply, this article was not helpful in my particular case. I hope this works for others, but it was not the key here.
Did you switch batteries between cameras? That would help isolate whether the issue is with the battery or camera.
That sounds like a poor connection someplace. In the future take a little extra time to ensure everything is snugged into place.
