  • 4 Replies
  • 2518 Views
Shenouda
I just got Alro pro yesterday and I don’t like it , because when the motion work send to my iPhone notifications too low and too short I can’t hear it , this morning the motion work 3 times and I didn’t hear it because it’s too weak, and I knew that there no Arlo pro notifications sound option on my iPhone and this too bad , i will return it because it’s too expensive and doesn’t give me what I need , please if you guys can fix this problem send to me
ShayneS
What version of the Arlo Mobile App are you using? Do you have the latest IOS 12.1.3 installed?
Shenouda
I installed right now, and there is nothing different, same option,
Shenouda
There is any way to fix this problem with the new update?
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
