  • 8 Replies
  • 2505 Views
Rschubert1988
I have reset unpluged the base and taken batteries out of the 2 of 4 cameras that are not recording to the cloud. What can i do to fix? It's been going on for 2 days now.
Rschubert1988
Problem solved itself. Didn't do anything I already tried before..
8 REPLIES 8
brh
@Rschubert1988
Is this a recording issue or are the cameras not connectiong to the base station. What are the LEDs on the cameras showing?
Brian
Rschubert1988
They are connected and can record video live and view live video but the 2 cameras wont save any video. The infrared light shows for 1 sec when it detects motion.
Rschubert1988
LEDs show nothing. But have light turned off
brh
@Rschubert1988
Have you checked your Rules from the Mode section of app to see if the rules changed to do nothing when motion is detected?
Are you getting notifications for motion?
Brian
Rschubert1988
The rules changed themselves to not record and i changed it back but thats when it stopped recording. Not sure about notifications
Rschubert1988
Yes I do get notifications
brh
@Rschubert1988
What camera models are you using?
I am not sure if this is part of the problem that others are having or not. Are your cameras integrated with Smartthings?
Are you using any schedules?
After resetting the cameras to record, are they switching back to Do Nothing?
Brian
Rschubert1988
