I have 4 Pro cams. A couple of months ago they quit recording after 4:45pm everyday. Can anyone tell me how to correct this?
Thanks.
Thanks.
Message 1 of 5
2,104
Reboot the base and use the Mode card. Click on your base in the first display and view the available modes. It would seem that you're likely using the Armed mode but see what is selected.
Are you using the schedule? Have you rebooted the base?
Message 2 of 5
2,102
I’m not aware of a schedule mode. I have searched for this on the app but can’t find it. No, I have not rebooted.
Message 3 of 5
2,099
Thank you very much. That’s exactly what was happening. Apparently I armed it to record on 8a-5p. I’ve turned that feature off now. I appreciate your knowledge.
Message 5 of 5
2,091
