Not able to replacement batteries for 4XH5777FC967B arlo pro
I have set of 3 cameras but none working as I am not able to find the batteries. what is a solution?
Also I do have base station - can I buy any new upgraded Pro 3 or Pro 4 camera and keep station the same?
4XH5777FC967B
4XH5777SC95DC
@mangesh wrote:Also I do have base station - can I buy any new upgraded Pro 3 or Pro 4 camera and keep station the same?
Look for a VMBxxxx label on the base, and then check the compatibility list here:
You will need a subscription with any of the currently sold cameras - none come with the 7-day free cloud storage what you have with the Pro / Pro 2 cameras.
Unfortunately Arlo doesn't sell them anymore. There are third-party batteries out there that you could try.
The cameras will run without batteries when connected to the Arlo charger - so maybe make sure the cameras are working before you get new batteries.
