One camera stopped recordin. I've spent two days looking for that place that has the pencil icon, as maybe I have a setting wrong (also I find is the word edit.. I don't lnow what to do. It worked when I set it up a few weeks ago. But I have tried to learn things and maybe did something when I was exploring my settings. And ideas? My other three cameras record.
Ok...
ARM all the cameras ( ARM in Mode )
Go to live View
Over each camera the "running man" should be BLACK ( guessing the one not working will be gray ( not turned on ))
Black means the camera is armed to detect motion
If the camera is gray, then the rule is incorrect
Go to MODE... go to ARMED... either the ">" or the pencil or the edit ( depnds on app/pc ) to EDIT
pick camera that was gray and edit...check the rule to make sure recording is turned on.
Ok...
Go to live View
Thank you. Very good instructions. Now working.
