No recordings (again)
Yesterday morning everything worked fine. Since then nothing. I rebooted the base station still no recordings. This same problem happened a few weeks ago but cleared up by itself after a few days. The infrared camera lights up so that's not the problem. For the first year this system worked great, now I have no confidence in it. The only time it works is when I do a manual recording. Is Arlo having issues upload to their servers again or is this something new?
Any suggestions??
The fastest thing to try is to reset the whole system and start fresh. That should clear out weirdnesses. It's a pain but if it works...
Thanks i will try this next time as it seems to be working fine now. Just like last time, after about 2 days of almost no recording it goes back to being normal by itself. I will see if resetting the whole system fixes it immediately and post the results.
Thanks again.
