No low battery or wifi icons showing on my computer. Used to be visible on Devices tab.
In the last 2 weeks, my computer no longer shows the battery or wifi icons on my 2 cameras. These used to be visible on the Devices tab. Now there is just a blank. Anyone else experiencing this? Thanks.
I've had issues like this recently myself but they seem to have resolved by themselves. You can try flushing the browser cache as well as using a different browser but I found nothing that helped until it self-resolved.
Still waiting for it to self resolve! i.e. still got the problem.
It shows up fine while using Edge browser. Have you tried a different browser?
We have Google Chrome on the computer. Not worth changing the browser for just one application, but thanks for the info, I'll investigate.
I don't have any icons missing, but mine all went to a very small scale. The mouse symbol is bigger than the feed symbols now.
Hi ksss11,
Do you have a screenshot that shows the icons are small? Make sure your page is not zoomed out.
