No low battery or wifi icons showing on my computer. Used to be visible on Devices tab.
  • 6 Replies
  • 2105 Views
  • 5 In Conversation
JanetteMcKenzie
In the last 2 weeks, my computer no longer shows the battery or wifi icons on my 2 cameras.  These used to be visible on the Devices tab.  Now there is just a blank.  Anyone else experiencing this?  Thanks.
6 REPLIES 6
I've had issues like this recently myself but they seem to have resolved by themselves. You can try flushing the browser cache as well as using a different browser but I found nothing that helped until it self-resolved.
JanetteMcKenzie
Still waiting for it to self resolve!  i.e. still got the problem.
dcfox1
It shows up fine while using Edge browser. Have you tried a different browser?
JanetteMcKenzie
We have Google Chrome on the computer.  Not worth changing the browser for just one application, but thanks for the info, I'll investigate.
ksss11
Virtuoso
Virtuoso
I don't have any icons missing, but mine all went to a very small scale. The mouse symbol is bigger than the feed symbols now.
JessicaP
Hi ksss11,
Do you have a screenshot that shows the icons are small? Make sure your page is not zoomed out.
