No Videos in library after setting up USB storage.
Hi,
I recently pluged off the USB storage from my system and since I did that I videos are not saved in my libary any more! how can I fix this? so videos continue to record in the cloud?
thank you
Have you tried restarting the base?
When you go to settings, your base, local storage what is shown there?
That's odd. I have never used USB recording and mine is set to on. Will it let you set it to on with no USB device attached?
Also, the windows app. says :-
Thank you
SD Card Recording (set to on)Automatic Overwrite (set to on)Enabling this allows new recordings overwrite old recordings when available storage falls below 5MBNo SD card plugged inWhen there is no SD option on the Arlo Pro's. I guess it's an error in the PC app.
I don't know where you got this unless it's a copy and paste from the Q cameras. The Pro base settings show:
I have tested this on two different Arlo Pro bases one at home and one at a client and it's the same when accessed via the PC app. It however shows correctly from my Android device.
On the one Arlo Q I have installed when I go to settings there, there is no local storage option.
I misspoke about the Q - should have said Q Plus. Sorry 'bout that.
As for the browser issue, I'd suggest clearing the cache as well as trying a different browser. I have tried using Chrome with no issues.
Tested with Chrome, Edge and IE with cache cleared on two different PCs, one having never visisted the https://arlo.netgear.com/#/login site.
Same result!! It's not browser related.
I think I found the quirk.
When there is no USB device plugged in it reports as an SD card as per my image.
When a USB device is plugged in then it correctly reports as it should.
Remove the USB device and it reverts to SD.
Netgear are lucky to have us as beta testers!!!
The SD on screen immediately changes to USB as I plug in the USB device.
When I unplug the USB device, it stays as USB until I log off and then log in again when it changes back to SD.
Try and remove the USB device then re-login.
As mentioned this is only on the PC interface not on the Android app.
