2 OF MY 3 CAMERAS HAVE NO NIGHT VISION. ALL THE FUNCTIONS ARE ON AND SAVED. I DO SEE A LITTLE OF THE IR WHITE GLOW IN THE CAM BUT NO FULL PROJECTION OF THE NIGHT VISION.. REALLY ALL BLACK.. ANY SUGGESTIONS??
Reset the cameras by opening the battery door and pulling the packs, then replacing....
Test again. If it continues, contact Netgear Support re the camera
ps; Semper fidelis
I CONTACTED NETGEAR BY SENDING THEM AN EMAIL...NOTHING YET. COMMUNITY IS THE ONLY HELP. OK I WILL TRY.. THANKS.
TUFEL HUNDEN
