I have charged my Arlo pro cameras many times with no problems. However today I plugged one in and there was only a flashing orange light, no blue. It does appear to be charging. Is this a sign of some impending doom?
A slowly flashing amber LED on the camera simply means that the battery is low. A rapidly flashing amber LED means the camera is not synced to the base station. You could try to remove the battery and plug the cable in and see if the camera flashes blue.
Brian
Well, it charged just fine and solid blue light appeared at full charge.
So I guess not a big deal. I will try removing battery and see if that makes a difference. Happy New Year!
