Night vision works on the video screen where you can pan aND tilt
First, bring the camera in and finish testing instead of putting up and down...
You can easily test the camera in a dark room / closet / etc as when light level fall, the camera automatically switches to B/W and uses the IR illuminators ( if toggled on ) when dark
Open the battery door and remove pack... replace same.
Go to settings and for that camera use REMOVE DEVICE... re-install the camera as if new ( quick push on base sync button )
Place in dark room and go to LIVE view, you should see the ir light on and the camera in B-W. Hit the Target icon to start a manual record, hit pause ( || ) to stop after 10 secs or so... Check cvideo in library
BTW; when the IR lights are on, (in dark ) you can see a reddish glow from the 8 (?) leds
Now in the dark room use ARMED and then walk in front of camera and see it it records on motion...again check library.
