  • 2236 Views
Stubb0402
One of my cameras night vision is not working. It detects movement the IR comes on and steady, but can not see in the dark. Any help out there.
Pull battery and replace to reset camera ( should auto resync )
test
If NG, go into setting and toggle the IR on and off a few times, save each time
Test
Stubb0402
@TomMac It worked once then stopped
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
