I just upgraded my cel phone with a new model. My account was initialized using my older cel phone. Now that I have the new Cel phone, the Arlo system will not arm/disarm using Geofencing feature. What do I need to do to get my new LG G4 to work with my Arlo pro?
GF works according to the phone's location services. Make sure that's turned on and maybe try the different settings there. Also, when you installed the app, did you allow all privileges? If not sure, check them in your phone settings for the app.
Yes, I know how geofencing works, I think the issue is because the Arlo system is not picking up my new cel phone. Do I need to delete the application from the original cel phone?
Have you disabled the old phone and enabled the new one in GF?
I uninstalled the Arlo app and IFTTT from the original phone. I am unsure how to enable the new cel phone on GF with the Arlo app.
OK, I found how to edit the preferances within GeoFencing mode, by opening the edit {pencil} icon. I then deleted my old phones within that option, leaving only the current one.
That worked, however I might need to make other adjustments, because the system seems to arm itself even when I am home.
Thank you for the support.
