New arlo pro won't work
Any suggestions??
How far is the base from your wifi router?
I assume all 3 green lights are on on the base?
Have you tried restarting your wifi router?
Last resort, factory reset the pro base also open and close the battery doors on the pro cameras to get them to reset too then try again.
yes, two of the 3 lights are on. The 3rd light which is the camera sync light just flashes yellow then eventually the camera times out
I have restarted the router
I have tried to factory reset the base and it won't reset, however I have taken all the batteries out of the camera, ensured they are charged and reinserted them
Still no luck...
Try and get some distance between the base and your wireless router.
The length of the supplied Ethernet cable should be enough.
The base sets up its own wireless network with the cameras and we want to make sure that your wifi router is not causing any interference.
See here fro instructions about resetting the base.
Make sure you're only briefly pressing the base sync button - don't hold it.
Fozzyaabb wrote:
Yes, thanks jguerdat. I have been only pressing it for a second or two and it goes into pairing mode. The cameras don't sync from there
two seconds is to long... atempt with a QUICK press on the base sync and then a sec later push the camera sync
