Need to replace camera and would prefer to connect to Solar Panel. Which cameras are compatible?
  • 1437 Views
Brendan1
I need to replace a camera I would prefer to connect it to solar
What cameras are compatible pls
Any camera starting with the original Pro can be connected to the appropriate solar panel (there are two versions due to the different power connection methods).
Brendan1
Thank you
So any camera will be compatible with my base station?
No. Since you list a VMB3000 base, you have to stick with the Pro 2, original Pro or more original wireless cameras. You may want to investigate the cost difference between new cameras and a new system that includes a different base or hub. That way you can use newer cameras and possibly have more features. If you go that way, I'd suggest looking at the Pro3 or 4 systems but a Pro or Pro 2 system would work.
