Need longer power cord for VMA4600 solar panel
  • 9 Replies
  • 7114 Views
  • 7 Likes
  • 8 In Conversation
David8906
How is it possible to have a longer power cord for the Arlo Solar Panel (VMA4600)? The length of 6 ft is about 2 ft too short to allow mounting to get good access to sunlight.
9 REPLIES 9
Not to my knowledge at this time
Sniperfi
I have the same problem. I was thinking of splicing a longer charge cord, such as the Arlo Pro Weatherproof 20ft/6m Cable by Wasserstein.
Techlore
It seems like getting a random extention cord might work(plugged into the Arlo wire)? Has anyone tried? I've been wondering.
Sniperfi, Techlore
NETGEAR does not recommend modifying or using an alternative cable as this could result in damage to the camera and/or solar panel and void the warranty. At this time, it is recommended to use only the cable included with the Arlo Solar Panel.
Sniperfi
I believe the Arlo solar panels are great. However, the power cord is too short. Someone at Arlo needs to make a 10 foot plus cable for the solar panels. I'm so tired of companies always telling consumers that modification will void warranty or damage a unit.
David8906
Well said!!
MostXcellent
Q: What is the name of this power cord. ? thx
peach-o
I need a replacement power cable for the VMA4600 Solar Panel. I have two installed in my 5-camera system, and accidently slashed the cable while installing a third Solar Panel.
Can I buy just the original equipment cable? There is no actual 'parts list' that comes with the panels, so I have no part number...
Try contacting support here and open a case. Maybe they would offer to send you a new one.
