Greetings,
i want to buy a camera system for my house. I was interested into buying the Arlo Pro. I wanted to ask if it is possible to connect the Arlo previous ones to the New Hub of the Arlo Pro. I need 4 cameras but i honestly only need one Arlo Pro. is it possible that i can buy the Arlo Pro (1 camera package with the hub) and the buy 3 Arlo old ones? Can all of them work on the same hub?
Yes, they are all compatible with both hubs. However, you should buy your one pro camera with the new hub so you can get access to the latest features (local storage, the alarm, etc) then buy the old ones.
