My camera outside is offline for the last 5 days
  • 6 Replies
  • 2460 Views
eskimopy5
My camera outside is offline fir the last 5 days. How can I️ remotely troubleshoot this and get it back online?
6 REPLIES 6
If the camera is offline, there in nothing to be done remotely. it usu requires physical interaction.
The base can be rebooted remotely but not the cameras
Don't forget that it's possible the camera battery is dead.
eskimopy5
There was about 92% charge the last I looked.  I have another camera on the back side of my house and one located inside and they are both functioning fine and online so I know the base is working.  My sister is offering to go to my house so I will have her switch out the one that is inside and then try to resync that one again.   I am thinking that is the one that was bought with a dead battery and didnt work from the start.  I then purchased an additional battery  and then after messing with it and calling tech support it then began working again.  Thanks for the replies!
A dead battery can be RMAed under the warranty. You don't need to buy a new one to fix the problem.
It's possible that the camera is the root problem but that's something support likely would have to help with. You can swap cameras and batteries around to see what remains constant which can point to the problem hardware.
eskimopy5
Unfortunaely, I bought the base with 2 cameras and then a single camera from 2 different places and had them with me in my apartment for about 3 months until I had some time off to return to my house on the East coast.  When I went to set up the cameras at my house I found I had a problem with a battery, that I thought was not able to be charged.  I did not have time to figure out the exact problem and it was easier to just buy another battery.  On my next trip home, I figured out the battery was good and got all 3 cameras up and running.  But now I am thinking the camera that is offline is probably the "problem" camera.  I am also thinking that it is something wrong with the door not closing snug enough or the contacts for the battery.  With all this said, I have no idea which company I bought which camera from so I just need to purchase another camera and move forward. Thanks for everyone's input!
There have been a few problems with the battery not making full contact with the camera contacts. The door doesn't push the battery in place so be sure to push the battery in fully. There's a little latch on the bottom that holds the battery in place - make sure it's clicked into place.
