  • 1912 Views
JerryR
Luminary
Luminary
I recently added an Arlo solar panel to one of Pro 2 cameras. For the first couple of days I would get a charging fault messages, either that day or by the second day. I dutifully followed the sugggestions to unplug the cable and / or pull the battery which always cleared the fault, at least until the next day.
But I noticed that, even with a charging fault indicated, the battery continued to charge. Since then, I haven't bother to try to fix the fault. When I see a charging fault message, somedays I'll clear the fault message, somedays I don't bother. So far, the battery has continued to charge when neccessary.
Has anyone else noticed this?
ShayneS
Hi JerryR,
Have you tried testing with a different camera to see if you still het the fault message?
JerryR
Luminary
Luminary
No, I haven't, mainly because it would require multiple trips around the house carrying the ladder, a tablet for aiming the cameras, etc. My first idea was take the solar panel back and get another one. Once I discovered that it was charging anyway, I kind of lost interest.
JerryR
Luminary
Luminary
I swapped the battery with the spare I keep on hand. No difference: some days there is a fault and some days there isn't. I do plan on moving several cameras which will give an opportunity to swap cameras.
